going to add superior plate kit to it , its ordered and on its way
and part one of the drum
10mm plate and 80mm id heavy wall pipe 40mm longer overall
may convert to drop boxs on front suspension too
coxsy wrote:got 50 metres of 12mm rope to fit on it from monstr
taz01 wrote:if you get the drum shaft outa an mk/mq pto winch its 50mm wider than the gq will save alot of time/hassle but will be off center as well the bonus its interchangeable with the gq winch
