80 series front diff 4.11
SamLogan
Post by SamLogan »
Hey i was wondering if anyone has a 80 series front diff for sale. Mate smashed his over the weekend.
Sam
mudlva
Re: 80 series front diff 4.11
Post by mudlva »
where abouts are you i have a factory diff locker for sale if interested
ClassicCruiserSpares
Need more info!! Complete diff hub to hub? Just the diff nugget? locker type or non locker? Just a housing?
SamLogan
Post by SamLogan »
um just diff head. smashed his crown wheel and pinion on the weekend. locked or non locked he doesn't mind
Sam
jammysammy wrote:smashed his crown wheel and pinion on the weekend.
Just out of interest how'd he manage that? the reason I ask is i'm going to be using an 80 front diff in my next project but may not if there week or may put in better quality ring and pin. :shock:
Also there just an 8" high pinion so be cheaper to get a prado one? I think there the same, someone else may know.
SamLogan
Post by SamLogan »
he was towing me out but he did it in reverse. Wasn't even pulling that hard but went bang. so i think a lesson has been learnt there
Sam
turoa
Pyro Junior
Post by turoa »
From memory prados only come in 4.3 and 4.8's
80 front diffs are notoriously weak in reverse cause of the reverse cut gears. I try and never put any load on mine in reverse and its been ok so far touch wood. If I were you jase id be cutting and shutting housings to put a 9" head in its place (same splines as an 8")
turoa wrote:80 front diffs are notoriously weak in reverse cause of the reverse cut gears. I try and never put any load on mine in reverse and its been ok so far touch wood. If I were you jase id be cutting and shutting housings to put a 9" head in its place (same splines as an 8")
Cheers for the info Tu's, thats something else i could consider.
red-devil
Post by red-devil »
yip they are weak as. i gave PR a tow backwards and ping, crunch, long drive home with the drive hub unbolted.
mud_slinger
Post by mud_slinger »
was a good cracking sound wen it went. good day tho. wer are the pics :wink:
needs more curry
0272593533
SamLogan
Post by SamLogan »
haha i am a bit too embarrassed to put them up. when i get them all i will put some up. So the guy who blew the diff has decided he is going to change ratios front and back and is therefore only looking for an actuator now as his got stuffed when the diff went.
Sam
