Megasquirt anyone used it
I'm thinking of installing it on my car but was wondering if anyone here has used it and if so what sort of issues did you have how easy or difficult was it to set up, what do i need to know before i jump in.
I have seen assembled kits for sale on trade me which is what i was thinking of buying
my 4wd is not a truck
Re: Megasquirt anyone used it
various mates have used them on their cars , 1uz 4age 3sge toyota motors with very mixed results, some never got them running 'right' and so worked like a microtech or a link would, i personally like the microtech with handcontroller
but if your on a budget do it, or if your on a budget and are very electronically minded build it yourself too...
mercutio wrote:I'm thinking of installing it on my car but was wondering if anyone here has used it and if so what sort of issues did you have how easy or difficult was it to set up, what do i need to know before i jump in.
had one on my trials truk, went great, no issues with it, am gonig to be putting one onto my rover next yr, bought the kit and built it, what you want to fit it to?
pedro
I got one is fine no issues and i can ajust shit sig has the back up so all good
Pedro wrote:what you want to fit it to?
pedro
i've got a mercedes 190e 2.3 16v am thinking of fitting it to that.
Are you running both the fuel and spark.
As a tinkerer am i likely to find it easy or difficult
Im running one in my Landcruiser, bought it with a 1uzfe tune so was just wired up and away you go. Runs great and less than half the cost of Links etc.
- Rotazuk
Built two , never finished a tune
91 Range rover part tuned before it was sold . Getting better than factory fuel consp , fuel only . Then put it in the suzuki with a ca18de to prove an issue . Fuel and spark but never tuned off idle .
I would say unless you build it and figure out what its doing , look for another computer . Also you would not want to chop up the wiring on that merc too much . Could do what I did with the rangie , got an old ecu , ripped the guts out and used the plug on that as an interface to the megasquirt . You can buy plugs for them these days but mostly american and japa's so far , when I last looked anyway .
Chris
Chris
theses cars came out with the old Bosch k jetronic mechanical fuel injection not much in the way of electrics so not much of a loom. heaps of vacuum lines and other stuff that is difficult to diagnose with out replacing everything one piece at a time.
have read online of guys fitting megasquirt to replace there old fuel injection and loving the results
anyone got a 4 330cc injectors lying around
apparently the 2jz-ge toyota motor had some about that size on it
So are you going to remove the mechanical injection and convert to electronic with the Megasquirt? Big job I would have thought.
Nice Merc by the way.
Matt.
Matt.
Mattman wrote:So are you going to remove the mechanical injection and convert to electronic with the Megasquirt? Big job I would have thought.
Matt.
yeah it won't be an easy job but i like a challenge and if it increases the performance of my car what have i got to loose i am lucky in that i have a spare engine to assemble the injection on before i fit it to the car itself
mercutio wrote:Mattman wrote:So are you going to remove the mechanical injection and convert to electronic with the Megasquirt? Big job I would have thought.
Matt.
now that is just cheating, but a good way to do it, can make brackets to hold crank sensors and the like, suggest you get a hall switch crank sensor for Diyautotune.com, save heaps of grief with crank signals, are you going with wasted spark setup?
Pedro
i'll get the fuel injection sorted first then think about the ignition side of things
done some more reading and think i will just go with an EDIS setup for the ignition but that won't be till a little further down the line.
i have also learnt it is possible to run megasquirt without modifying the original wiring harness in these cars which goes to show how much electrical stuff is involved in the original fuel injection
