Afternoon all!
I’ve managed to get a 2nd had ARB compressor with all the bits for a bargin (only couple weeks old) it came with all the wiring, but no diagram or anything to help me out what goes where and into what etc.
Can post up some pics of the wiring if that would help or if anyone has the original box with instructions that would be fantastic!!
Thanks in advance
Dan
ARB Onboard Air Compresser
Re: ARB Onboard Air Compresser
Well wired up the compressor tonight all going well until I tried to turn it on.....nothing happened the lights with the dash lights worked but nothing else, anyway swapped the red, red/yellow around and away she went GREAT!!! but the light that indicates that the compressor is running or not stays on no matter what, so then tried some other combinations and now the light works as it should but no compressor at all GRRRRRR!!! So cant figure out whats happened checked all fuses and bits but nothing from the compressor ](*,)
Any ideas?
Thanks in advance
Dan
Any ideas?
Thanks in advance
Dan
I've wired 3 of them up, 2 with factory looms and one with a home made loom and everythings always worked ok so maybe you want to go over it all and recheck the wires are connected to the right places, sounds like your stabbing in the dark a bit if your swapping wires around
Wiring diagram 12v
http://www.offroaders.com/tech/images/R ... volt-p.jpg
Wiring diagram 24v
Wiring diagram 12v
Wiring diagram 24v
right was stabbing in the dark a little lol, but all sorted just had 2 wires running from the relay to the switch around the wrong way
o well all happy now.
