td27 eti
Posted: Thu Dec 15, 2011 4:14 pm
by navara66
Can the newer nissan td27t eti motors be converted to run a mechanical injector pump off the older td27t. I am not realy wanting all the hassels with the wiring loom ect but want the newer low km motor.
Re: td27 eti
Posted: Thu Dec 15, 2011 5:39 pm
by nissantd27
they sure can
Re: td27 eti
Posted: Thu Dec 15, 2011 5:49 pm
by navara66
nissantd27 wrote:they sure can
Is there much work i have found a 1996 td27eti with 118k for $750 but just want to swap all the manual pump gear over. Can you tell me some more info.
Re: td27 eti
Posted: Thu Dec 15, 2011 5:52 pm
by KIWI_TERRANO
you could always get the td30 ( the 3ltr intercooled) out of newer terrano and put your manual pump on that to, then get Diesel services to tune it
Re: td27 eti
Posted: Thu Dec 15, 2011 7:11 pm
by tweake
KIWI_TERRANO wrote:you could always get the td30 ( the 3ltr intercooled) out of newer terrano and put your manual pump on that to, then get Diesel services to tune it
TD30 ???
you mean ZD30? if so then you can't fit a manual pump to that.
QD32 is the other one, 3.2 turbo. easy enough to fit a pump to that.
Re: td27 eti
Posted: Thu Dec 15, 2011 7:30 pm
by KIWI_TERRANO
tweake wrote:KIWI_TERRANO wrote:you could always get the td30 ( the 3ltr intercooled) out of newer terrano and put your manual pump on that to, then get Diesel services to tune it
TD30 ???
yes sorry that what I ment
Re: td27 eti
Posted: Fri Dec 23, 2011 2:47 pm
by navara66
Are the injector pumps a straight swap, or is there more to it.
Re: td27 eti
Posted: Tue Jan 03, 2012 9:17 am
by slide
Hmm this has got me thinking...
Does the qd32 bolt up to replace td27? Ie engine mounts and bellhousing the same? This could be a potential power upgrade
Re: td27 eti
Posted: Sat Jan 07, 2012 11:21 am
by TD power
yep mate they bolt up
Re: td27 eti
Posted: Sat Jan 07, 2012 6:00 pm
by navara66
TD power wrote:yep mate they bolt up
Thanks TD power thats what i wanted to know.
Re: td27 eti
Posted: Thu Jan 12, 2012 3:49 pm
by R_ace-link
Hey TD power,
does the QD32 injector pump fit the TD27eti engine???
and is there a upgrade for the TD27eti Turbo? ( it's got the TB25 on it)
regards,
Race
Re: td27 eti
Posted: Thu Jan 12, 2012 10:05 pm
by TD power
yip the pumps swap over good turbo upgrade is get ur one custum rebulid by steve much how much boost you whant to run
Re: td27 eti
Posted: Sat Jan 14, 2012 9:36 am
by R_ace-link
Hey TD,
well there seems to be 2 problem
#1
I don't want it to be custom build, becz if something happens to it then I'm out of a turbo. would be better if I could buy a upgrade one from ebay and swap it with the standard turbo.
#2
and I'm from Suriname, somewhere in south-america. so would be impossible for me to let it be customized by Steve
. Would be one expensive custom turbo though
i'm thinking around 17-18ish psi would be good. what ya think, I just need to get the boost a little sooner.
so what kind of a turbo do you recommend
Garrett would be great, becuz there are a lot of them on ebay.
so let me know what ya pondering
Race
Re: td27 eti
Posted: Wed Jan 18, 2012 10:23 pm
by TD power
get a garret gt28r-7 mate that will spoll real fast and give good top end
Re: td27 eti
Posted: Mon Jan 23, 2012 2:29 am
by R_ace-link
A little on the expensive side but, I'll go with your advise.
I'll keep looking around second hand shops if I could find 1 laying around.
cheerio, and thanks.
Re: td27 eti
Posted: Sun Mar 25, 2012 11:11 am
by wax
R_ace-link wrote:Hey TD power,
regards,
Race
Have you tried this turbo on a td27 ??
Im building something close to this
Re: td27 eti
Posted: Thu Jul 05, 2012 10:51 pm
by hammd
it may fit but how do u run the electronic qd32 pump?
regards,
Race
Re: td27 eti
Posted: Sun Jul 08, 2012 12:31 pm
by wax
the n/a qd32 was a mechanical pump
Re: td27 eti
Posted: Tue Jun 11, 2013 9:13 pm
by thestig
did anybody ever sort this out? i have a td27eti and have fitted a mechanical pump off a td27 what pump gear do i use td27 or td27eti? thanks
Re: td27 eti
Posted: Tue Jun 11, 2013 9:27 pm
by wax
Its was never in question to be sorted out
you can use a td27 pump on a qd32
you can use a qd32 pump on td27
you can use an early td27t on a late model td27ti
They are all interchangeable, if you want the best one out there get a bd30 pump with the 12mm head
Lots of fuel for lots of boost
