Macetown - 27 Dec 11
Re: Macetown - 27 Dec 11
were abouts is the tunnel do you remember? never found that up there before?
rough 'n' ready
As you head in after about the 10th crossing you start to climb. You leave the river and climb high above it. After about 800m? of climbing there is a track of to the left that drops quite sharply down, just by a big vent vertical pipe. Get to the bottom of the hill then turn right. Watch the 3rd crossing down that hill if you don't have a snorkel or take it slowly.
Water no longer flows through it, it was a great swimming hole when growing up but dry now.
JR wrote:were abouts is the tunnel do you remember? never found that up there before?
If you go to the visitor centre at the museum in Arrowtown you should be able to buy a guide of the Macetown Track...this will tell you what your looking at & where to find it .
Scoles Tunnel is about 2.7 km from Buckingham st ...there is a small track off to the left that leads to the tunnel.
Entire track from Buckingham St to the end at Andersons battery is about 13.8 km long ..so wont take too long .
prety sure thats all blocked off?nice camping spot just by it. you can drive up a bit further, but starts geting a bit prestine,if you jump up on the pipe you get a nice easy walk up to the dam,crawl through afew tunnels dug for the pipe (tightish). you can keep you feet dry though
rough 'n' ready
You can drive to the tunnel, well you could a few months ago, camping there is good if youcan handle the sandflies!
wjw wrote:Back in 2003....
Tunnel is now blocked.
Pedro
