hey everyone, does anybody know if 33" mud tyres will fit on my ln60 surf without any lift?
33's on ln60 surf
- BeamedSurf
- Bush Crasher
33's on ln60 surf
Toyota Hilux Surf SSR LN60 Beam Axle
Build in progress
Build in progress
- tomsoffroad
- Flopsie
Re: 33's on ln60 surf
Yip but they'll rub on the foot wells
- BeamedSurf
- Bush Crasher
rub insanely? or just whilst flexing?
Build in progress
Build in progress
- tomsoffroad
- Flopsie
Just while flexing
- BeamedSurf
- Bush Crasher
awesome, thanks for the help mate
Build in progress
Build in progress
i put 33s on my ln61.after lifting the torsions up and 50mm on the rear springs was only getting small rub in wheel arch so fixed it with a big hammer,now all good apart from bending the idler arm
In the back of the wheel arch there is a seam where the footwell meets the side of the truck. If you've still got the plastic liner inside the wheel arch you'll need to pull that off and then beat that seam flat with a hammer... that'll save you cutting the heck out of the tyres while flexing... all the rest of the rubbing will just be annoying, but that seam will be $expensive$ if you leave it there.
Steve
Steve
