difference between 2lt and 2lte
- BeamedSurf
- Bush Crasher
is there much difference between a 2lt and 2lte in terms of the wiring? i.e will a 2lte fit in a truck that used to have a 2lt in? and will a 2lte box fit on a 2lt? i just bought a g/box off tradme and it has alot of extra wires compared to the one that i took out, im guessing the new one is off a 2lte, it is also electronic speedo where as the old one wasnt, is it easy to switch from mechanical to electronic now that i have a gearbox with the plug for electric speedo?
Toyota Hilux Surf SSR LN60 Beam Axle
Build in progress
Build in progress
- BeamedSurf
- Bush Crasher
Re: difference between 2lt and 2lte
lol i realise that, i mean the loom and shit in my truck wont fit on a 2lte? or will it?
Build in progress
Build in progress
To put a 2LTE in a 2LT truck will be difficult.
There is the loom, ECU and all the relays required...
I wouldn't bother myself...
The manual pumps are more user friendly....
The box will have a few extra bits mainly electronic speedo pickup for 2LTE system....But wont effect your 2LT....
- BeamedSurf
- Bush Crasher
pretty much just dont hook all those extra wires up ae (cos obviously there will be nowhere for them to go
cheers for the help mate
Build in progress
Build in progress
The other way to do it, is take all the electronic gear off the 2lte, and put manual 2lt bits on.
That would be the way if you have a blown 2lt and have found a cheap 2lte to go in. Bear in mind there are different sumps between models that may need to be swapped over, and possibly oil cooler assembly different??
Electronic speedo sender should pop out, and cable one pop back into its place.
Been awhile since I played with this, so I'm willing to stand corrected if I'm wrong at all
- BeamedSurf
- Bush Crasher
the old 2lt motor and box are gone, just picked up a cheap 2lte box tiwh 150000ks on it for $350, now just need a 2lt motor and an exhaust
Build in progress
Build in progress
