Help!! rear axle shaft wont go back in
brakes-shocks-lockers-etc
sambo
Post by sambo »
hey guys changed both my back wheel bearings today and now passengers side axle wont go back into place, sits about 40mm out from where it should, the splines not catching,
ive tried filing down splines a bit to get to line up and nothing,
any suggestions as im booked on a 8.30am ferry tomorow morning :roll:
pos nissan patrol
Ln106 single cab
muddyhilux
Re: Help!! rear axle shaft wont go back in
Post by muddyhilux »
wiggle wiggle wiggle,how can you tell splines aren't catching with diff head in?they can be a pain sometimes but you'll get it
stinky
House Hubby
Post by stinky »
jiggle it lots there a bugger but keep at it
____________________________
Martin
http://www.wtbs.co.nz
oldblue
Post by oldblue »
Turn the Pinion Fange as you insert the Axle
sambo
Post by sambo »
pretty sure i had mushroomed the head of the axle a bit, causing splines to be too wide to fit into the center.
I grinded off a wee bit around the first 10mm of axle/spline ( :shock: :shock: ) and she popped in first try after that, much easier than the past hour with a tiny little file trying to get it to work,
cheers for your help everyone
pos nissan patrol
Ln106 single cab
