Finally fitted intercooler
Posted: Sun Jan 01, 2012 12:10 pm
by Hombrey
Guys I finally got round to fitting my air to air intercooler and its worked out pretty well so thought I'd drop a post. Bought it a while ago. 300x300 top mount air to air. Made up some brackets and mounted it square over the rocker cover at the back and about an inch under the bonnet when shut. Then added some draft stop stuff to form a seal when the bonnets shut. Also mounted a scoop off an Isuzu bighorn with the bonnet hole cut to match the intercooler size. The intercooler is 100mm thick and level with the bonnet angle. With a 2 inch body lift at the front of the cooler I have about 80mm clearance to the top of the rocker cover and at the back about 130mm so easy enough to fit a pull fan under the cooler if need be. Test drive is showing more top end power and about 100c drop in EGT's under full load at 15psi so am wrapped with that. Also found that bipassing my snorkel filter set up and using a pod filter means I make boost much faster and hold it under load where before boost was slower to get there and then would fall off. I assumed the revs were just sucking it up but looks like my old filter system was under feeding the turbo so suspect it would make boost till it formed a snorkel vacuum then drop off. Anyway works great and well worth the frigging round to fit the cooler. Plus the cooler and scoop look cool on these big bonnets.
Re: Finally fitted intercooler
Posted: Mon Jan 02, 2012 8:22 am
by slide
More power + drop in EGTs. Awesome 8) .
You got any pictures to share?
Posted: Mon Jan 02, 2012 8:45 am
by Hombrey
yeah will take some and post them up.
Posted: Sun Jan 08, 2012 7:37 pm
by Hombrey
Bit slow but find attached pics of my air to air intercooler fitted.
Posted: Sun Jan 08, 2012 7:47 pm
by sibainmud
Nice 8)
Nissan TD's respond well to this sort of mod.
100 deg drop seems to be the norm.
Good work.
Posted: Sun Jan 08, 2012 9:47 pm
by HARD L200
damn thats a tidy install mate. good on ya.
Posted: Mon Jan 09, 2012 8:23 am
by Hombrey
Yeah pretty happy with it. Here is the scoop.
Posted: Mon Jan 09, 2012 8:52 am
by HARD L200
that actually looks good. makes it look more beefed up.
