Wanted: Patrol GQ PTO Output shaft Seal info
Terry
Post by Terry »
Hi folks, my PTO box is leaking gearbox oil onto the extractors, really stinking up the truck... Has anyone replaced theirs who remembers the output shaft seal specs or part numbers? Kinda dark at the mo to go pulling it apart, rather get the bits then just throw them in if I can... cheers, Terry
monstr
Re: Wanted: Patrol GQ PTO Output shaft Seal info
Post by monstr »
Hi Mate will get you the seal numbers tomorrow ,i have just rebuilt all my winches ,got the seals from bearing supplies up here in Auck .were only about $6-8 each
Terry
Post by Terry »
awesome :D cheers, Terry
monstr
Post by monstr »
Hi Mate the numbers on seal are AE1351E NOK.
Terry
Post by Terry »
sweet - Seal Imports translated that into a 25mm x 47mm x 6.35 seal, I've gone with their closest, a 25 x 47 x 7mm, in viton (hopefully a bit more temperature resistant than the old one - the extractors are about 20mm away...) I'll see how it fits tomorrow - worse case scenario I have to take the old one in, but this gives me an excellent chance of a same-day repair.
thanks heaps, Terry
monstr
Post by monstr »
Thats the same ones that i got from bearing supplies they work fine.
Steve
