info on terrano wanted
For all Nissan related topics
benorange
Post by benorange »
looking at buying a 96 3.2 with 220km on it
what things do i need to look out for and check first.
also what are they like on diesel.
rolla4wd
Re: info on terrano wanted
Post by rolla4wd »
seat and seatbelt mounts in rear rust ( not sure what years)
If it has and its been fixed I think it needs a cert if its on the road
someone else on here should be able clarify that tho
sibainmud
Post by sibainmud »
rolla4wd wrote:seat and seatbelt mounts in rear rust ( not sure what years)
It's a R50, not applicable.
Those ones have been known the have trans issues that cause over-drive to be dopey and the torque converter won't go into lock up mode.
Trailing arm bushes can get worn causing the arse end to wobble around a bit. Apart from that mostly all good.
TD power
Post by TD power »
airflow meaters and diesel pumps intake hose splits auto trans is beater than d21 dash clusters pack up good for RUC :lol: :lol: other wise ok dont get ZD30 hand grenade
