escudo fuel pump problems
howdy guys, trying to get the escudo that i brought for parts going b4 i pull it to bits. The fuel pump isnt going and the truck wont start. Its not the fuel pump as i hardwired it and it works fine and the truck will start. Ive looked at the wiring diagram and realise that the pink and black wire is goes to the pump. when the key is turned on the fuel pump relay ticks off after about 5 seconds but the pump doesnt go at all. Ive checked the fuses in the box and tried switching the FP relay with the ECU power relay and nothing. Ideas anyone?
Re: escudo fuel pump problems
there is a loom behind the rear left tail light, you could check continuaty from relay to there (or straight to fuel pump) to make sure its not just a broken wire. otherwise last time i had this problem it was the ecu
where are you? i think i opened the ecu and could smell the burned out smell immediately
vinceparts
just hard wire it to your ingition barell.... if your stumped
yea cheers for the help guys, i got sick if mucking around with it and ended up ripping the engine out today anyway. Im gunna pull the whole loom out to be stripped down to do into the samurai. Ill open the ECU up and have a sniff, guess ill just cross the bridge when i come to it when me and Tu's to the transplant into my sammy. Chur
