Now i carry a spear alternator in my truck (brand new stock one) but just wondering if its a good idea to do a upgrade? Was thinking a EF falcon 110amp? Worth doing? Or stick the new stock vitara one on?
Any ideas would be great
Tim
tow99 wrote:Dont fit a falcon alternator. I have a mate that is a ford wrecker and the falcon alternators fly out the door as fast as they get out of the cars because they crack regulators and fry themselves and the batteries in the system. Anything au and after are better but ea eb etc are crap.
HedgeBoar wrote:The problem is that your winch will pull in the order of 600 amps or more. Adding batteries helps for very short pulls, but even with two decent batteries you're talking a matter of tens of seconds 'til your alternator is the main limiting factor.
DieselBoy wrote:
If you stand by what you have just stated, then according to your statement above, you would need to fit a 600amp alternator to winch for longer than 10 seconds.
The alternator has absolutely nothing to do with winch performance during a pull and everything to do with battery recovery time between winches.
HedgeBoar wrote:No -- what I meant is that to winch AT 600 AMPS, continuously, for longer than a matter of seconds, you'd need either a 600amp alternator or a really huge battery.
