ln61 park lights and tail lights not working HELP!!!!
dumpedln61
Post by dumpedln61 »
So today i found out that my park lights and tail lights are not working
my brake light will work if i put my foot on the brake and my head lights work
same with all the indercaters
have checked all fuses and are all mint
can anyone help?
lm61
Re: ln61 park lights and tail lights not working HELP!!!!
Post by lm61 »
hey there i hve the same trouble! i posted a forum lastnight about it there is some info on there. does your back window work still??
bigstu
Post by bigstu »
have you checked the fuses under drivers side kick panel under dash?
jonossiksilvia
Post by jonossiksilvia »
have u checked to see if switch stalk working properly. thats wat happen with mine
ladeda
Post by ladeda »
Hey mate, sounds like a few people having the same problem.
safe enough to asume its not a globe problem due to all parker lights not working.
If theres definatly power coming in and then out of the fuses and conections are clean and good my next step would be disconecting the plug to the light switch stalk, normaly hidden around the stering column somewhere and checking for power there. You can try bridging the wires to see if the light start working.
Just make shure you DONT bridge two powerd wires together or youll be replacing fuses.
rangimotors
Post by rangimotors »
put in a new head unit or dicked with any wiring behind the dash recently?
lm61
Post by lm61 »
i discovered my problem was that you Mr dumpedln61 when i purchased the surf off you you had not plugged in the park light switch on the dashboard by the radio!!
