Rock Gardens Pictures
leeogrady
Post by leeogrady »
http://www.sensitivedatasystems.co.nz/mud/
4th Jan: Me and mudlva at the top. Totally forgot about photos of the trail this time.
8th Jan: First winch section of rock gardens, broke my upper trailing arm just before here so didnt make it any further this time. Last pics show damage... bugger.
MNC
Re: Rock Gardens Pictures
Post by MNC »
Awesome pics, looks like a lot of fun.
Hey, what spring set up are you running?
Looks like a Rangie top 3 link but cant see the coil mounts on your diff :?:
http://www.sensitivedatasystems.co.nz/m ... .05.50.jpg
Drurban
Post by Drurban »
Were is that picture taken of the two trucks????
Is that at the end of the Rock Gardens??
Also in picture 15 on the second set of photo's how far is that from photo 1 as in timing wise or distance??
I have only walked to the first corner as in the first picture.
leeogrady
Post by leeogrady »
@MNC: Thanks! it was fun until the breakage and 5hours to get back down! Im not 100% sure, the setup of the suspension was done when i got it, the links and mounts all look custom made. it is a 3link, the axel is a 40series landcruiser. The coilover shocks are mounted to the diff very basically, nothing flash! You can actually see it in the photo you posted the link to...
@Drurban: the single picture of two trucks is right at the top of rock gardens. Pic 15 is the first real winch, which is at the end of a straight (ish) from pic 1, probably about 200meters..
Drurban
Post by Drurban »
Hey thanks leeogrady, that has made it a bit clear for me.
Those are great photo's.
