looking at upgrading springs
pajeroboy
Post by pajeroboy »
well im lookn at upgrading the springs on my 91 pajero short wheel base,i keep hitting bumb stops and it kinda saggin in the ass and bit down on the left side,just wondering if a set of lwb springs would fit in as ive been told that they are longer and stronger than mine,would this work or if anyone has any other ideas tht mite help,any info would be good
thanks guys
33" muddies, 50mm body lift, ball joint flip, quick release front sway bar,40mm lifted rear dobi springs and new shocks,custom sill body armor,custom front bar.
SAM
matwelli
Post by matwelli »
I may have a spare set in a week or so, keep in touch. The LWB ones are an upgrade option for you, you are welcome to try them out if you want.
Mathew - 021 441 043
pajeroboy
Post by pajeroboy »
sweet,yip if u have a set id be keen to try,waht sort of condishion they in,do they fit into same mounts then?
SAM
NJV6
Post by NJV6 »
Yes, they fit easily. Take the shock absorbers off at the bottom then either support the vehicle and lower the axle or lift the body & chassis and the springs will pull out.
LWB are heavier than the Swb ones & another useful lift is used Poootrol springs however they may cause driveline viabrations if gone to high.
Patrol/Safari rear springs are the same diameter as Pajero ones.
pajeroboy
Post by pajeroboy »
cool as,mite have to find me some
SAM
Daz
Post by Daz »
There is some on trademe of 1991 SWB Pajero with a 50mm lift.
NJV6
Post by NJV6 »
Those ones on trade me with a 50mm lift are chamberlain springs - well they look like them anyway. I have some in mine - they do give a wee lift but are also possibly firmer. Ideally I'd have some the same rate as the originals but longer.
Daz
Post by Daz »
pajeroboy
Post by pajeroboy »
yeah lookd at both then,does anyone reall no what the deal with cert is?i got a body lift and 33",seam to get told lots of diff things,getting :?
SAM
NJV6
Post by NJV6 »
Daz wrote:He says they are TJM springs
http://www.trademe.co.nz/Browse/Listing ... d=65039942
Opps Sorry, My bad. :oops: There were some others on there as well that I was thinking of - Red ones.
