Runva winch seal help.
Hey guys, taken my winch apart to service it and for some reason the large seal that runs against the drum to seal the motor side has ripped/shredded for some reason?? So water has been getting in.. Any chance anyone knows where i could find one of those large odd seals, tryed Mike but doesnt have anything in sock. Cheers Ben
Re: Runva winch seal help.
If your in welly go to Pacific Seals and they will make you one.Ask for a price first,goodluck.
Seal imports, Seal house, advanced seals, auckland bearings come to mind.
Good luck, Ben.
Good luck, Ben.
Bummer about the seal Ben, but looking forward once it is all together it will look way different.
How long did Mike say he would have seals in stock???
Cheers for the replys, tryed auckland bearings today - no luck. Will try seal imports. Yeah Ruben it should look good, the paint has turned out mint so far hopefully it wont flake off like the orignal stuff!!
I have some winch drum seals for our winches, not sure if they will fit.
Can you post a picture and put up some sizes and I'll check to see if they might work for you.
Cheers Brett
021 724 309
Cheers Brett
021 724 309
Not the best pic. Anyway roughly measures from the back 110mm o/d, 100mm i/d. the ring that sits in and hold the seal to the housing is about 4mmx4mm, hope that makes sense. Cheers
Sorry Ben,
It looks like our ones are different in shape and fitment.
Hope you can find something that will work.
Brett
Brett
Appreciate the help Brett, (maybe i should of gone for a tigerz11)
Cheers, Ben
Cheers, Ben
Have you tried contacting Runva in Australia for the said part?
Ph 0212078472
Ph 0212078472
Nope, thought they just came straight from CHINA, will check out google. cheers
They are now in stock again. Give me a call 021535007.
Cheers Mike, That is really quick reliable service!!!!!! mission is now over, get to slap it back together
You are welcome mate! Now go give that winch a hard time - it loves it
Happy Winching.
