my pitman arm, tierod ends, uper balljonts and center link
went to ripco all the parts i needed $480
$307
Any way when i did my 2" lift i keeped the standard shocks and as i have the truck in bits i'm doing all the jobs i need to so WHAT ARE YOUR THOUGHTS ON THESE SHOCKS
Rancho rs5000 f-Max length:381mm. Min length:246mm
r-Max length:609mm. Min length:375mm
$133 each
Rancho rs9000 f-Max length:368mm. Min length:263mm
r-max lenght:562mm. Min lenght:362mm
$195.50 each
EFS Elite - Firm Valve code. Max length:595mm. Min length:363mm
$194.29 each
EFS Elite. Max length:318mm. Min length:205mm.
$190.19 each
Raw Nitro f-Max length:355mm. Min lenght 232mm.
$176.82 each
r-Max length:561mm. Min lenght 356mm.
$166.37 each
thanks
p.s and what do you think about steering damper they range from $53 to $88
