Tyre size change.wofs,Certs and insurance
- jonossiksilvia
Re: Tyre size change.wofs,Certs and insurance
they will not pay out if mods wernt certified and listed on your policy
- muddyhilux
hey mate,yes a lot of people do put larger tyres and get away with it if done in proportion to vehicle.and plenty of wof shops let it through etc etc.when coming to a crash though yes it can be a big out for insurance companies as the vehicle is illegally modified as anything over 5% should be certified to say brakes are still operational within specs and the speedo has been corrected so you don't speed
as for what's involved in certs.if only tyres then pretty easy.take truck to cert shop.certifier will go over truck,take for test drive,then send away paper work.bout 2weeks later certifier will call you,you return and he puts tag on truck and you're done,oh he'll also take about $500 off you
muddyhilux wrote:if only tyres then pretty easy.take truck to cert shop.certifier will go over truck,take for test drive,then send away paper work.bout 2weeks later certifier will call you,you return and he puts tag on truck and you're done,oh he'll also take about $500 off you
um not always that easy you've still got to get the truck to pass the brake test with oversized tyres and its often not that easy to get through with bigger tyres
- muddyhilux
Sadam_Husain wrote:muddyhilux wrote:if only tyres then pretty easy.take truck to cert shop.certifier will go over truck,take for test drive,then send away paper work.bout 2weeks later certifier will call you,you return and he puts tag on truck and you're done,oh he'll also take about $500 off you
um not always that easy you've still got to get the truck to pass the brake test with oversized tyres and its often not that easy to get through with bigger tyres![]()
this can be true,but when saying just tyres i can only assume such as a 33 instead of a 31 maybe,any more than that ie 35+ and you'd be doing lift or guard chop aswell etc
