LN106 rear diff noise
Posted: Sat Jan 21, 2012 8:39 am
by uptomynutsinruts
Hi all,
My hilux real lsd is making a shitty, squeaking noise when reversing and when changing down while slowing up for intersections etc. Its only when in gear and under load i.e.clutch out
Of course this happened the day I put it up for sale :roll:
It looks like it might be leaking a little amount of oil out the front of the diff head (pinion end) which it has never done before.
The LSD still works great, can turn sharp corners on road and inside tire will light up a little as it always has so I'm thinking that it may be a bearing or seal but then again I know 3/5 of 5/8 of f##k all
Any help would be greatly appreciated
Or if anyone wants to buy a hilux I'll do it for 7 grand with the diff the way it is haha
Cheers guys
Re: LN106 rear diff noise
Posted: Sat Jan 21, 2012 10:12 am
by vinceparts
Sounds like the universal on the drive shaft, mines been doing that for a month now and the rear uni seems on its way out
Posted: Sat Jan 21, 2012 10:47 am
by uptomynutsinruts
Its leaking oil out the pinion and theres a bit of movement up and down in the pinion. Just got quoted $1300 to fix...F##K THAT!!
Posted: Sat Jan 21, 2012 10:51 am
by rangimotors
you can get a second hand diff head for 250-350 spend another 50 on diff oil and sealant and put it in yourself for a cheaper option.
Posted: Sat Jan 21, 2012 11:03 am
by samewan
what ratio do you need i got a 4.8 for sale atm?
Posted: Sat Jan 21, 2012 11:32 am
by hosehustler
If it were a diff pinion fault you would hear a distinctive whining noise when either accelerating or de-cellerating, which gradually becomes worse over a period of time.
i'm definately with the others on a driveshaft universal, they cause the bulk of drivetrain noises and vibration, very common fault. Your's will have a two piece driveshaft and a centre bushing....that centre bushing/bearing is often faulty, what i'd replace first :wink:
As for the oil coming from the pinion, nothing to do with the squeak you're hearing....a new seal can easily be fitted with diff in place.
Posted: Sat Jan 21, 2012 11:52 am
by uptomynutsinruts
Hosehustler, if that bushing is naffed, will there be a lot of freeplay or will it be hard to know? At the moment I dont have a lot of time and even less money as I've just shifted to ahburton, thinking about maybe selling it for a while and buying a car for travelling back on weekends and buying a dedicated off road hack.
are the universals expensive to replace? its making a screeching noise and its only when downshifting or reversing e.g. the diff is under load to pull the truck to a stop/in reverse
cheers for the help guys
Posted: Sat Jan 21, 2012 11:57 am
by hosehustler
not usually huge amounts of play visually, circle track engineering do good prices for universals etc, give them a call monday morning, discuss exact noise you're hearing and get some solid advice before selling your truck cheap.
Posted: Sat Jan 21, 2012 12:03 pm
by uptomynutsinruts
Yea thanks mate, looks like im gonna have to leave the truck at a mates and borrow his honda to get me back to ashburton for the week :lol: :lol:
Can you get the centre bushing from BNT?
