Well I need a new accelerator cable as my old one has worn beyond use any more.
I went to get a new one but where I would normally go they have moved. So where to go? or does any one have a spare? its for a carby G16A Vitara
need it for Sunday.
Lincoln
0210642798
Need an accelerator cable
Lubrication Specialist
Lubrication Engineers
Re: Need an accelerator cable
If you take your old one into any Autostop store they can have a replacement made. hope that helps. Cheers
If you follow me in the bush you must be mad cause I'm plain CRAZY !!!
1987 BJ74, 13BT, Auto, 35" Wranglers, 80mm Suspension Lift, 2" body lift, LSD rear, ARB Front Locker, PTO, Lots of Steel and a Go Hard Driver.
Bugga, had a look and only came up with 2 clutch cables
unfortunately Autostop is a bit far from me.
Just ordered a new one from Suzuki for $53, not too bad. Not as bad as a quote I got from trademe for a second hand one for $75
and thanks suzookyman, all the same.
Well zuk is up and running so will be at the Sunday of the nats. yay.
and good ol' winger gave me the cable for trade, so was only $52 incl GST.
Now to swap chassis'
