Scottish Sami build
For all Suzuki related topics
farmerboy4
Stropper
Scottish Sami build
Post by farmerboy4 »
heres a bit of info about my zuk.
based om 92 samurai
1.6 vitara(escudo?) 16 valve efi
6.49 rock lobster transfer box
rear lock right
Rear disk conersion, disk converted hand brake
3" lift springs, still spring under axle
extended steel brake lines
tray backed rear and tubular front wings, cut down summer doors
front gigglepin 8274
rear good winch g10
3x optima batterys, relocated fuel tank from donor vitara.
265/75r16 insa turbo special tracks mounted on modified Grand Vitara steel wheels, cut out and re-welded to increase offset
160a alternator off range rover p38
standard shafts and C.V`s
It was built for winch punch events and play days.
Ive got a set of Land rover axles im thinking of fitting still undecided.
hope you like it
mercutio
Re: Scottish Sami build
Post by mercutio »
looks like a great toy
my 4wd is not a truck
wayfastwhitee
Post by wayfastwhitee »
thats awesome. must go pretty hard with gearing that low haha
Filthy4x4
Post by Filthy4x4 »
Looks awesome dude. That winch looks huge :shock:
027 MUD GEAR - (027 683 4327)
Check our facebook:
007
Post by 007 »
As borat would say "very nice"
I bet you wish it was here.
ford ranger wildtract and sj.
Dr_PC
Post by Dr_PC »
Looks and sounds good. The fun you could have with that out here
sambo
Post by sambo »
how do you find the gigglepin? ive heard good things about them but never seen them over here in nz
pos nissan patrol
Ln106 single cab
UBZ
Post by UBZ »
nice looking zuk ..
apart from the crazy death shackles up the front :shock: :shock:
how does it go on gravel / dirt tracks at speed?
Apm83
Post by Apm83 »
Be interested in what the sand/mud matting/bridging material is on the rear of the truck.
Swamped
Post by Swamped »
I've seen similar looking stuff used on a couple zuks down the road from me. I'm pretty sure it was just ali grating. Seems to be really good and not an arm and a leg like those max track things.
Apm83
Post by Apm83 »
Swamped wrote:I've seen similar looking stuff used on a couple zuks down the road from me. I'm pretty sure it was just ali grating. Seems to be really good and not an arm and a leg like those max track things.
Hmmmm got me thinking.
Wonder where you'd get them from in NZ...
ice4x4
Post by ice4x4 »
They a referred to as "Waffle Boards" and are made of glass reinforced plastic. They will support the weight of your truck are lightweight and will never corrode.
Like these ones.
http://www.paddockspares.com/pm1070-waf ... -38mm.html
1988 Range Rover Classic
2010 Discovery 4 HSE 5.0 V8
Swamped
Post by Swamped »
Only saw them on two imported trucks, one was from scotland funnily enough. The ones I saw definitely seemed metal though being silver under paint. They also looked used ie a bit bent. Didn't try lift one so could be wrong. Google calls em bridging ladders too, not cheap.
Looks like they would be lightweight until they got full up with mud?
ice4x4
Post by ice4x4 »
Well they aren't as light as aluminium but can support the weight of your truck. Yeah mud will weigh them down to.
Cheap for me, we have 5m x 2m sheets of the stuff on the ship. Just cut myself a couple and took them home from Mexico :lol:
Tarmac
Post by Tarmac »
Try asking around for tread plate, punch plate or expanded ...(mesh?), cant remember exactly what the last 1 is called. Cut it into sections required and get some heavy but not too big (30x30ish) angle or box, taper ends and zig on edges, poss 1 in the middle. Steel or ally
I reccomend use on smallish 4wds only, to prevent excess warping recover using alternate sides.
On second look they seem like a butchered plastic pallet.... mean lookin ute though,
LR90NZ
Post by LR90NZ »
Apm83 wrote:Be interested in what the sand/mud matting/bridging material is on the rear of the truck.
What he has on the back is commonly referred to as 'waffle boards' in the UK. They are a fibre planking that resembles a waffle hence name. Quite common in UK and available in various sizes up to 50mm thick.
Sometimes you see a similar type of product used on the DoC walking tracks around the place rather than the timber platforms they used to make.
Due to their strength they will support the wait of a vehicle and help cross ditches, climb rocks etc.
They weigh a bit especially the larger sizes.
The alloy planks you often see on exhibition vehicles and used in the Camel Trophy events are referred to as sand ladders. ideal for laying on the ground to help traction, especially across the deserts. Originally these were used for laying airfields during WWII. Cut down they became useful 'sand ladders' for crossing the Sahara but they can't support the weight of a vehicle like the waffle boards.
I have both types and have brought a few sets of the waffle boards in from the UK from time to time but they aren't cheap to ship in.
Return to “Suzuki”
