my tail lights dont work
hey i have just purchased a 86 lm61 surf and my tail lights dont seem to work and the park lights? the breaklights work fine im stunned any comments??
Re: my tail lights dont work
checked fuses they seem to be good i got told to unplug my headunit and see if they worked after that but i did and nothing had changed so i am still abit confused.. i have a few issues like my back window switch doesnt work i have to hook up these two wires to a battery to make my window go up and down anybody know what that would possibly be aswell cheers
lm61 wrote:checked fuses they seem to be good i got told to unplug my headunit and see if they worked after that but i did and nothing had changed so i am still abit confused.. i have a few issues like my back window switch doesnt work i have to hook up these two wires to a battery to make my window go up and down anybody know what that would possibly be aswell cheers
I think there is a sensor switch in there which disables the up down. It plays up .....
should have a good look at the condition of your fuses, had the same sort of problem no radio, clock but the dash lights were sweet, turned out to be a fuse which i had already checked the pin bits were lightly corroded, put a brand new one in a way she went got radio, something small and simple can cause a bloody headache sometimes
possibly in the switch if ya have checked everything else like fuses/ globesetc, try unpluging at plug conector to light switch and bridging earth with each other wire one at a time and seeing what comes on. can also use a test light to check for power at switch, if has power there then check at light sockets, also could be a bad earth.
yea i agree double check ya fuses mine was the yellow 60a main fuse. also for your window check the canopy switch it under 1 of the bolts holding the canopy on think its 2nd or 3rd bolt from the back on the left side. i just bridged mine out.
