hey guys, carb on my sammy shat itself. Need to buy slash borrow a replacement to get me to chch. Doing a 1600 conversion once im there just need it to get me down. Cheers
Blake
G13 carb wanted
- Rotazuk
Re: G13 carb wanted
Go to pick a part and get one off a barina . They have auto choke , think you have to ditch it ( IE I remember wiring the choke full open ) . Bolt it on and plug in the fuel cut wire and away you go . Will get you to chc , hell had one on my 413 for a couple of years .
Chris
Chris
Re: G13 carb wanted
Rotazuk wrote:Go to pick a part and get one off a barina . They have auto choke , think you have to ditch it ( IE I remember wiring the choke full open ) . Bolt it on and plug in the fuel cut wire and away you go . Will get you to chc , hell had one on my 413 for a couple of years .
Chris
cheers chris, got an autochoke one off a swift at the wreckers thismorning. Im a bit confused by the vacuum lines tho as they are slightly different. Is there anything tricky u have to do to get it right?
