Ignition wiring help
Posted: Mon Jan 30, 2012 7:41 pm
Well after lots of thinking..i'm still puzzled. Its a toyota 4Y carby with points distributor. Now whats got me confused is the wiring to the coil. There is wires from the loom connected to both coil + and -, and the wire from the distibutor is connected to the coil +. This is where I am stumped.. shouldnt there just be a positive feed to the coil from the loom, and the distribtor (points) wire should be just connected to coil - ??? Then I would pressume the other - wire is the tacho signal. Are my thoughts right..or have toyota in thier wisdom got it wired the other way? Tacho works, engine runs almost as well as i think it should.. And it has had a the body replaced so possible someone has wired it back in wrong. There is only the 1 wire into/out of distributor, so doesnt make sense to me that its connected to the + side of the coil..surely that would do nothing other than short thru the points.
Anyone got any thoughts? Or better a picture of the coil on thier 4Y/3Y? Before I start tutu'ing
