gas bump stops do they increase/allow more upwards travel
and are the road legal
gas bump stops
Re: gas bump stops
your bump stop hight is set to stop shit smashing into other shit with upward travel so trying to change your bump stops to get more upward travel will probably result in a whole pile of new problems to deal with
- niblik
- Sausage Shack
Re: gas bump stops
http://www.radflo.com/hydraulic.htm
bump stops are engaged during the last few inches of compression travel to help cushion heavy impacts.
- MNC
Re: gas bump stops
The advantage is you can limit travel in certain circumstances if you wanted to. ie, on road or speed sections or maybe if fitting bigger tires - times when big flex can be a hindrance instead of helpful.
I imagine this mod would need a cert (but thats a guess).
