surf_tomo
Posts: 229 Joined: Mon Oct 29, 2007 12:00 pm
Post
by surf_tomo » Wed Feb 01, 2012 3:49 pm
as title says I have just discovered that the wheel arch has come away from the firewall, here are some pics
whats the best move from here? should I be concerned?
Cheers Tom.
sibainmud
Posts: 1846 Joined: Sun Apr 04, 2010 9:27 am
Post
by sibainmud » Wed Feb 01, 2012 6:12 pm
surf_tomo
Post
by surf_tomo » Wed Feb 01, 2012 7:34 pm
rodger rodger. It feels like a soft sort of a join. what is the best way of repairing it? Cheers Tom.
Filthy4x4
Posts: 1052 Joined: Mon Dec 20, 2010 2:51 pm
Post
by Filthy4x4 » Wed Feb 01, 2012 8:03 pm
I was just about to post that
027 MUD GEAR - (027 683 4327)
Check our facebook:
Posts: 5200 Joined: Tue Jun 20, 2006 12:00 pm
Post
by coxsy » Wed Feb 01, 2012 8:51 pm
a panel shop or do you have a mig welder, its the spot welds that are broken,
sibainmud
Post
by sibainmud » Wed Feb 01, 2012 9:02 pm
As Coxsy says it can be spot wielded. I am wondering what the cause is though
Do you have body lift? or do you just hammer the crap out of it like I did mine
DieselBoy
Posts: 4568 Joined: Sun Nov 14, 2004 12:00 pm
Post
by DieselBoy » Thu Feb 02, 2012 7:05 am
If the body mounts are good and tight then i personally wouldn't worry to much. It's probably just the chassis flexing with the off road use that has caused it. Seal it up again and just monitor it for a bit. Don't panic and go spend a grand on getting it welded at a panel shop!!!!!!!!
lax2wlg wrote: Is that like saying 'she's hot, for a crackwhore??
surf_tomo
Post
by surf_tomo » Thu Feb 02, 2012 7:36 am
Ill check all the body mounts today, the hilux is not body lifted. The same looks to be happening on the other side tho not so bad - just starting from underneith. Dont have the skills to repair it myself
UBZ
Posts: 1649 Joined: Sat Aug 19, 2006 12:00 pm
Post
by UBZ » Thu Feb 02, 2012 8:04 am
doesn't look that bad to me at all. I'd undo the 8-10 bolts holding the outer guard on and have a look from the inside . then just seal it back up and monitor it
LR110 ..... LJ50 project
surf_tomo
Post
by surf_tomo » Thu Feb 02, 2012 2:22 pm
2 body mounts on each side were not tight. nipped them up. hope no other damage has been done, at least I found it before it parted company completely . Cheers Tom.
Post
by coxsy » Thu Feb 02, 2012 3:19 pm
great nice to hear you won on this issue
surf_tomo
Post
by surf_tomo » Thu Feb 02, 2012 3:42 pm
something else to add to the never ending repair list
kbjj
Posts: 712 Joined: Sat Apr 10, 2010 3:51 pm
Post
by kbjj » Fri Feb 03, 2012 9:56 am
I"ve got signs of this happening too. The chassis flex's more than the body can handle. Bulletproof's done a great wee mod to prevent this, longer body mount bolts with valve springs added. Been meaning to do mine.
surf_tomo
Post
by surf_tomo » Fri Feb 03, 2012 11:47 am
Oh hell that sounds alright, do you know roughly where in the 80 pages it is? Great thread that one, read some the other day
kbjj
Post
by kbjj » Fri Feb 03, 2012 1:45 pm
surf_tomo wrote: Oh hell that sounds alright, do you know roughly where in the 80 pages it is? Great thread that one, read some the other day
Nah... sorry
