Head Bolts
dtchch
Head Bolts
Post by dtchch »
Does anyone know somewhere I could get a set of new head bolts for my Suzuki?
Suzuki in Christchurch want $150 for a set of 10 :roll:
Mine are ok but would like to replace them if I can do it for cheaper than $150!
Could I take them into a place which does fasteners and bolts, and see if they have anything suitable or should I just reuse the old bolts.
Overkill
Re: Head Bolts
Post by Overkill »
Pop down to BNT, cheap for head bolt kits compared to buying from dealers, I just did the head on our Holden and saved $60 by using BNT. Don't re-use, get new 8) I
boon
Re: Head Bolts
Post by boon »
Whether you should reuse the old ones depends on if they are torque-to-yield or not... TTY headbolts shouldn't be re-used.
Unfortunately I have no idea whether Zuk headbolts are TTY or not.
dtchch
Re: Head Bolts
Post by dtchch »
Cool will check out BNT, would much rather replace the bolts
