Which Pyrometer?
Which Pyrometer?
As I'm doing a lot of towing in the 80 I thought it would be a good idea to install a pyrometer.
Can anyone suggest which one they find good for the money?
Cheers.
Cheers.
Re: Which Pyrometer?
DIGITAL EGT THERMOMETER PYROMETER W/ PROBE-NPT, Blue you can buy these on ebay they are the same ones that chip it use so they must be good, and they charge 400 for them
http://www.ebay.com/itm/DIGITAL-EGT-THE ... 2eaf7a26dd
Interesting. Not bad for NZ$120. when you compare it to this for a similar price.
http://www.trademe.co.nz/motors/car-par ... 017876.htm
And you can do so much more with them turn your fan on have an alarm go of at a set point, and just found out they do boost to My EGT is playing up mite have to order one myself
petefj40 wrote:http://www.ebay.com/itm/DIGITAL-EGT-THERMOMETER-PYROMETER-W-PROBE-NPT-Blue-/200512513757?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2eaf7a26dd
hi pete, are you going to order 1 in?would you be able to purchase 2 and i will buy one off you?
cheers tony
would be keen on one as well
i"ll take 1 too
Got mine from here as have a few other people on ORE.
Good service & a quality product.
http://www.auberins.com/
I've been looking at this one - not in stock yet but quoted $179 for a combination pyro and boost guage
http://www.trademe.co.nz/motors/car-par ... 907554.htm
At $109 this looks good too - with adjustable warning light...
http://www.trademe.co.nz/motors/car-par ... 356506.htm
Maurice
KZN185, 1KZTE running needing birthday
i have a autogauge 52mm one which is still working fine.
i had a autogauge 60mm one but have replaced that with one from http://www.auberins.com/ . i find the digital easier to read, has remote output for the warning (in the middle of wiring up a warning buzzer this weekend) and it has max/min memory recall.
there is a choice of sensors and can be programmed for other sensors.
for the $$$ the auberins one is the best.
tallsam66 wrote:Got mine from here as have a few other people on ORE.
That Ebay one is an Auber instruments one by the way and I paid less than that from the auberins website.
I have those guages too. Is cheap and goes well has alarms/built in relay for buzzer or whatever you want, etc.
I have three of them now (same module is used for multiple stuff), water temp, EGT and Boost.
Wouldnt use anything else now.
Heath
Cheers fellas.
I'm liking the digital display to the analog one.
- Bulletproof
If you want the best this is what I run.
A VDO the same as the ships and helicopters use. They are not cheap but extremely accurate and Swiss made. I paid around $800 for mine about 10 years ago
Cheers Richard
Cheers Richard
Never say die, up man and try
Cheers Richard.
$800 is a bit steep.
Just had a search on ebay for one.
http://www.ebay.com/itm/VDO-Vision-Elec ... 56484224df
Looks like the price has come down some what.
As said can't beat Auberins
This is the one you want.
http://www.auberins.com/index.php?main_ ... cts_id=230
Excellent service and fast postage.
Can choose between C and F...also.
pic of the Auberins digital gauges with 60mm autogauges on the right.
the boxes the auberins gauges are in are off their website. the gauges normally come bare which can be handy if you want to install them in the dash etc.
make sure that price includes the sender and wiring,
i also have a VDO and they are right up the in price
hey pete, let me know what you get, need one for my truck too.
Who knew Prados could fly?
kbushnz wrote:As said can't beat Auberins
Cheers!
I think I'll order one this week.
Bill. Shall I double up on the order? And if so what colour and sensor would you like?
Giza txt.
021-100-1408
vinceparts
i ordered a auber pyro last week, took 7 days to turn up, very very compact and really well made
very happy compared to the chinese ones on trademe
vinceparts wrote:i ordered a auber pyro last week, took 7 days to turn up, very very compact and really well made
Out of interest. Which courier service did you choose?
Pete any chance you spodded a unit that will that mutiply inputs.
I.E. water/oil temps, water/oil pressure, EGC
I'm trying to keep the boy racer look out of the truck
vinceparts
petefj40 wrote:vinceparts wrote:i ordered a auber pyro last week, took 7 days to turn up, very very compact and really well made
the cheapest one
red-devil wrote:Pete any chance you spodded a unit that will that mutiply inputs.
i found some that where muiltiguage and specially for diesels, but most of the sensor where displayed on the tiny lcd in the centre. i doubt you could read it when your driving.
Can anyone tell me how you reset the peak reading from the Auberins gauge. I have misplaced the manual that came with the gauge..
Thanks
Thanks
download a new one from here
http://www.auberins.com/index.php?main_ ... 4b55861810
Thanks mate. Now why did i bother posting here. I should have just text you..
Ginzu8 wrote:Thanks mate. Now why did i bother posting here. I should have just text you..
Press and hold the ^ key for 3 seconds.
I didn't realize they were so small.
All good.
This is how it looks fitted into the dash.
