Came across this on trademe http://www.trademe.co.nz/motors/car-par ... 620696.htm
don't know the guy but seems a good deal.
Al
Cheap Ground Anchors
suzookyman
pruggerdore
Re: Cheap Ground Anchors
cheap enough but if the angles are wrong be hopeless. need to be a proven design which it may be but the angles look wrong to me from others I seen
- land bruiser
i recon i could make these cheaper than what hes asking. Ive been meaning to make one to use on my 60 serries. I havnt seeen one in the fleesh so need to do a bit more reserch. But wouldnt be that hard its only a bit of plate and box section. Do many people use these would there much demand for them. Im looking for a something new to keep me busy. i normaly make alloy bash plates for dirt bikes but been doing it for a number of years now so be keen for a new project
I HAVE 60 SERRIES PARTS FOR SALE
pruggerdore wrote:cheap enough but if the angles are wrong be hopeless. need to be a proven design which it may be but the angles look wrong to me from others I seen
What should the angle be? ....do you have some plans you can post of a proven design?
get a anchor from a winch challenge truck that has been well tested
pruggerdore
tallsam66 wrote:pruggerdore wrote:cheap enough but if the angles are wrong be hopeless. need to be a proven design which it may be but the angles look wrong to me from others I seen
NO and thats the trick. copy a proven one. and bigger isnt necessarily better plus you have to carry the thing on in the truck too. will be making one eventually and just copy someone elses
I've got a couple here I could maybe be persuaded to measure up, at a pretty good guess I'd say they are both a direct copy of the old firma grips, I've only used the red one when we took it to the costa tuff truck teams event a couple of years ago and it seemed to bite and hold in the soft paddocks over there but it hasnt been tried in any harder ground?
Turoa did some R&D on the yellow one to see how robust it was on the 3 times slow roll then 2 1/2 times roll at highspeed off a clift backwards with no brakes landing in a beech tree and other than a very slight tweake it came out A+
i can confirm its robustness on the rollovers, altho we never actually got to use it marty. Where did u get the photo of him in the trees? is it one of yours? id love a decent copy if u could send me one
BlakeJ wrote:i can confirm its robustness on the rollovers, altho we never actually got to use it marty. Where did u get the photo of him in the trees? is it one of yours? id love a decent copy if u could send me one
nah I didnt take any photos it was off the winch challenge thread below, you can find the owner of the photo in there somewhere, I guess nobody was quick enough (or expecting) to get the second roll
Wellington Winch Challenge Nov 25/26/27
pruggerdore
look at the angles in the pic's above and then the pic on trademe. see what I mean
