Wanting to Mod my Vitara...
Re: Wanting to Mod my Vitara...
Hi what kind of Vitara do you have? Engine, year and number of doors would be good.
Mudbits it te puke does a lot of suzuki bits and knows them inside out
Give him a call
http://www.trademe.co.nz/services/trade ... 022966.htm
Where abouts do you go wheeling? Im in Whakatane
Give him a call
There's a couple of way you can go with the tyres:
-After market rims and a body lift. 31x10.5x15 should fit
-Std rims and a bit of panel work. 245/75/16 (30.5) should fit
Suspension lift:
-50mm lift springs
-Front strut extenders or a strut hat flip
-Commodore shocks in the rear (longer travel)
-Hiem joint spacer for rear a-arm
-Remove the sway bar
Do a sreach on this forum, Kernels has a good write up on lifting a zook.
Suspension lift:
-50mm lift springs
One of the best modifications that I ever did to mine was to have a bash plate made. It went from under the radiator support to the cross member between the lower suspension arms. Either 4-5mm aloy or 4mm stainless. Stops the crossmember acting as a plough in the ruts and slowing you down. Guaranteed not to regret it!! Calmini do one but an engineer will do a simple one at a less cost.
