Assorted questions (escudo mainly)...
Posted: Tue Feb 14, 2012 10:06 pm
by Filthy4x4
Righto, well after 2 days of testing the zuk in a paddock I managed to rip a rear shock out of the tower, drop all the transfer case oil and then pop the bottom of the same shock out :roll:
Needless to say its going under the knife (don't worry, build thread will be coming :mrgreen: )
First off I will start by saying its dedicated offroad, so its not going to be pretty with branded parts, im on a mission to build/fix/mod everything I can for it.
The questions I have are as follows:
1. What front shocks will fit the front that will give me a very decent extension ( I have commy shocks in the rear)/
2. Does anyone have a zuk on hilux diffs?
3. What factory rims have a decent offset? (15" 6 stud)
4. What springs fit the suzuki front top hats that are soft? Im aiming for a decent amount of flex.
5. Does anyone have any pics of the front end setup on a escudo with coiled hilux diffs?
Thats it for now, had more to ask but got serious brain fade while typing the first question out :lol: I will post up more when I find more things I need to learn :mrgreen:
Caleb
Re: Assorted questions (escudo mainly)...
Posted: Tue Feb 14, 2012 10:12 pm
by zukmeista
As for the first question, you need to flex it up and measure between the shock mounts at full extension and full compression. This will determine the appropriate shock.
Posted: Tue Feb 14, 2012 10:20 pm
by Filthy4x4
zukmeista wrote:As for the first question, you need to flex it up and measure between the shock mounts at full extension and full compression. This will determine the appropriate shock.
This is the problem im facing... it doesnt flex in the front :lol: its rock hard.
It apparently has mitsubishi v3000 shocks in it with factory zuk springs and top hat, but im thinking it might be a v3000 spring as well, the ride is absolutely horrible (leaves would be a huge luxury in comparison).
Posted: Wed Feb 15, 2012 2:44 pm
by churchill
OME are the only ones I know of but I do have the drawings for strut extenders, I can get them made for $150 a pair but I will have 2 for sale soon
I'm just about to do that conversion
Don't know, I used standard rims as the wheels can tuck up under the guards.
Don't know, remove the sway bar will help heaps.
http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=168&category_id=47&option=com_virtuemart&Itemid=53
Posted: Wed Feb 15, 2012 3:12 pm
by SP450andLE
uwshho wrote:4. What springs fit the suzuki front top hats that are soft? Im aiming for a decent amount of flex.
Mebbeh Lada springs?
You're welcome to come round and jack the Lada up and take a spring out, compare it to a Zuk one, and then put in back in and jack it down again 8)
Posted: Wed Feb 15, 2012 4:44 pm
by Filthy4x4
churchill wrote:The questions I have are as follows:
Thats the kind of flex im wanting from the front... too bad there was no further info on that setup.
I havn't got any sway bars at all :twisted:
Could be keen on the drawings of the strut spacers
Are you going with coils or leafs on your conversion?
Posted: Wed Feb 15, 2012 4:45 pm
by Filthy4x4
Sweet as might be a plan if I cant find anything that suits
Posted: Thu Feb 16, 2012 9:23 am
by churchill
I've bought that kit.
Posted: Thu Feb 16, 2012 3:56 pm
by Filthy4x4
Oh awesome, might have to ask you for a few specs later on. Im liking the way they set up the trailing arms
Posted: Fri Feb 17, 2012 8:00 am
by churchill
No worries, I'll let you know when it arrives so you can check it out before it goes on if you want.
