hey guys does anyone have a stuffed g13 engine they want to sell the sump and oil pick up off. Putting a g16 in but dont see the point in pillaging the sump and pick up off the good g13, thought i might aswell sell it.
Blake
oil pickup and sump
Re: oil pickup and sump
I've got a buggered G16a, will that sump fit?
dtchch wrote:I've got a buggered G16a, will that sump fit?
thanks for the help but nah it wont. i have the g16a complete engine but need to 13 sump so it fits in nice without needing SPOA lift.
bump, anyone have one lying around. does the barina or swift have the same shaped sump?
- PuddleJumper
BlakeJ wrote:bump, anyone have one lying around. does the barina or swift have the same shaped sump?
Swift or Barina dont have the same "drop" as the 413 does.
Your in CHCH now right? I know of an SJ I can get my hands on for change, not sure what is under the bonnet. I was thinking of buying it and parting it out/wrecking it like you did the Vit. Depends on what the demand is really...
DISCLAIMER
Yea i am in chch, sorry to be ignorant but did u buy some of the vit off me did you? well if its cheap it wud def be worth parting out. If you do get it i could be keen on some bits depending on what you will have and my swindling student budget
bumpity bump
a g13 pick up wont fit a g16 oil pump, the diameter of the g16 one is about twice that of the g13 item...........
pretty sure a g16 block is wider where the sump bolts on than a g13 is aswell.......
strx7 wrote:a g13 pick up wont fit a g16 oil pump, the diameter of the g16 one is about twice that of the g13 item...........
nah the g13 sump fits perfectly, its needed as the g16 sump would clear the samurai diff. The pick up has to me a merging of the g13 and g16, you need to tig the two together
