Hey all.
Been meaning to adjust the steering lock bolts since the insurance put another front axle under my 71 series.
I seem to have better lock to the left than turning to the right and it is worse than the original axle.
Keen to adjust to the maximum that I can. I drive lots of hairpin bends one after another which is why I got the 71 series rather than the 78 series.
My question is how far can I go before it is too much? What are the likely issues, other than tyre/chains rub.
Anyone know?
Prado 7x series max steering lock
- IcedJohnno
- Trailer Trash
Re: Prado 7x series max steering lock
cv's pop easier the further they turn and if you go too far that could be pretty instant.
- IcedJohnno
- Trailer Trash
So how far is too far?
The lock adjustment bolts must be there for a reason, rather than just having a casting lock stop, would you not think? If I wind these bolts fully home will it be too much?
Anyone know?
Anyone know?
Its a good ? i think there will be a degree setting in a book somewhere. to do mine I looked at all the swivel ball housings in deranged's shed and looked at the wear marks from the felt seals etc. got an indication from that and took a stap in the dark. hopefully someone has better knowledge to share with us
