suzuki diff ratio
butcherboy
- Bush Crasher
suzuki diff ratio
can anyone tell me how i can find out what ratio i have
Re: suzuki diff ratio
butcherboy wrote:can anyone tell me how i can find out what ratio i have
pull the diff out and count the teeth on pinion and crownwheel
unless you might like to give just a wee bit more info...
Suzuki LJ10
Suzuki LJ20
Suzuki LJ50
Suzuki LJ80
Suzuki SJ410
Suzuki SJ413
Suzuki Samurai
Suzuki Jimny
Suzuki Vitara
Suzuki Grand Vitara
butcherboy
- Bush Crasher
lilpigzuk wrote:butcherboy wrote:can anyone tell me how i can find out what ratio i have
pull the diff out and count the teeth on pinion and crownwheel![]()
Suzuki LJ10
Suzuki LJ20
Suzuki LJ50
Suzuki LJ80
Suzuki SJ410
Suzuki SJ413
Suzuki Samurai
Suzuki Jimny
Suzuki Vitara
Suzuki Grand Vitara
they are out of a v6 thats all i know just want to see if someone has already put the 5,12 in already or if they are standard thanks
4.825 is standard for a v6 auto. 5.125's are worthwhile with 31's
- Rotazuk
Jack one wheel off the ground . Count how many times the drive shaft goes around for one revolution of the jacked wheel and then doule it . ie if the shaft goes around 2.5 times its a 5:1 diff . if it goes around 2.3 times its a 4.6:1 etc . will be too hit and miss trying to guess between a 4.8 and 5.12 .
Rotazuk wrote:Jack one wheel off the ground . Count how many times the drive shaft goes around for one revolution of the jacked wheel and then doule it . ie if the shaft goes around 2.5 times its a 5:1 diff . if it goes around 2.3 times its a 4.6:1 etc . will be too hit and miss trying to guess between a 4.8 and 5.12 .
Actually, turn the driveshaft 2 complete revolutions, and your wheel will do either just shy of 5 turns or just over 5 turns telling you if it is a 4.875 or a 5.125
