would it be possable to body swap a 94 tarrano with a patrol.
how differnt are the chassis ect would this be possable
a nissan question
Re: a nissan question
So you want terrano body on safari chassis?
Its possible, but you'd need to dedicate a lot of time to measuring up and checking how far different chassis width, lengths, mounts etc. Then have to work all wiring, piping, steering etc etc. No small task.
Would be a mint conversion tho!
It would be easy the most important thing will be chassis length to suit wheel arches.I did a ute so only had to get the front right and a flat deck on the back.Spend some time looking and measuring.Just thinking mine is a 4 cyl as the big 6 may not fit in the Terrano engine bay.
Sketchy_Racer
Good luck getting the straight 6 TD42 under a terrano bonnet, theres a reason the safari bonnets are a kilometer long
If running a different motor then as per above post
