1UZ Snorkel Sizes?
1UZ Snorkel Sizes?
Hey guys, Just wondering what a 1UZ would need as far as snorkel size diameter? 2.5 or 3 inch ?
To Boon or not to Boon.
vinceparts
Re: 1UZ Snorkel Sizes?
id go 3 inch, 2.5 inch looks waaay to small and its prob better to have bigger rather than smaller
Ours is 3" and I'd go bigger if we were to redo it
Hmmn, I might have to, I`ve already bought $70 of 2.5 Stainless tho, oh well better to do it right first time...
vinceparts
2.5 inch use for part of exhaust before it joins?
T-Boon wrote:Hmmn, I might have to, I`ve already bought $70 of 2.5 Stainless tho, oh well better to do it right first time...
If you have enough make two....one for each side??
Twin snorkels
- muddyhilux
id be going 3 plus.i havd the 3 inch on my 2y and didn't even go near hooking it up to my 350.id be wanting atleast 1x 4 inch but if i get things sorted it'l be twin 4 inch
vinceparts
depending on what type of stainless bends or straight you got , i could be keen on buying it off of you, making an exhaust to replace the fukt one on the 2.8
vinceparts wrote:depending on what type of stainless bends or straight you got , i could be keen on buying it off of you, making an exhaust to replace the fukt one on the 2.8
One 90, One 45 and 2m straight.
Whats it worth to you ?
vinceparts
ill give ya fiddy for it , just bought 5 stainless 90's in w.e for fiddy, tube bending in east tamaki , there seconds bin is rad, i dont even know why half of it is seconds
Sweet, only paid $70 so works out well, hope 3 inch isint too much more expensive...
4" inch for sure
made one each side, with twin air filters
Went with 3 inch, will see how it goes, should be fine.
T-Boon wrote:Went with 3 inch, will see how it goes, should be fine.
You should be fine with 3' as the throttle body on the 1uz is only 3' dia so if u go any bigger the air is only gona bottle neck at the throttle body anyway i reckon , going to put a 3' on my hilux soon ill let you know how it goes after i put it on.
4 " would be best.. having a 3"now.. beit a little late..lol
I've made a 3' for mine which runs from the throttle body (drivers side) to the left hand guard and up the A-pillar even with that much piping and only 3' it seems to work fine - no noticable difference to power between the snorkel and just having a pod filter straight off the throttle body. only thing i've found is that if the passengers window is down the induction noise can get a little annoying after a while
nztimr33 wrote:I've made a 3' for mine which runs from the throttle body (drivers side) to the left hand guard and up the A-pillar even with that much piping and only 3' it seems to work fine - no noticable difference to power between the snorkel and just having a pod filter straight off the throttle body. only thing i've found is that if the passengers window is down the induction noise can get a little annoying after a while
This is exactly my setup. Seems to work fine.
