1975 swb FJ40 bolts
brakes-shocks-lockers-etc
Pj_Marsh
1975 swb FJ40 bolts
Post by Pj_Marsh »
Hi guys
Just found your site and looks like you've got some keen fj40 fanatics who might be able to help me out. I've bought an fj with the intention of rebuilding it from the ground up. Got as far as taking the body off and grinding out the rust. What I can't seem to get is a complete bolt list from toyota, so I can bulk order the lot without spending to much. Anyone know where I could get one, offhand? Don't need the engine ones as I am putting a 12H-t into it.
The other thing is leaf bolts. The old ones are shot, and from 4wdingbits.com they are about 79 each. Crazy.
Any help would be appreciated, cheers
Re: 1975 swb FJ40 bolts
try jase (classiccruiserspares)
Pj_Marsh
Post by Pj_Marsh »
Thanks I'll give it a shot
williamhamilton
Post by williamhamilton »
niblik
Post by niblik »
really....?
how about just remove bolt/bolts as ya go and label it/bag it with how many ya need, then go down to blacks or similar and buy anew..?
try jason at classic cruisers... he could sort ya 'shackle pin' issues..
either that or head here for a nosey..
http://coolfj40.stores.yahoo.net/
Pj_Marsh wrote: so I can bulk order the lot without spending to much.
If its a ground up rebuild the cost of the bolts will just be loose change :mrgreen: just go and but some boxes of metric bolts you'll soon use them all up :D
Pj_Marsh
Post by Pj_Marsh »
Some handy links there, thanks guys.
really....?
Really really. Bolts go to the four winds when im taking them out
here is the bolt kit page, nice guys son dealt with them when he did some body work on his fj40
http://coolfj40.stores.yahoo.net/boltkits.html
rangimotors
Post by rangimotors »
Bolt kit eh coxy? ha ha ha nice
dam, you had me worried I put the wrong tag up :D
nice looking chick :D though
badnuz
Post by badnuz »
do you mean U bolts for the leafs?
Pj_Marsh
Post by Pj_Marsh »
Not the U bolts that secure the axles to the leafs, but the ones that fix the leafs to the chassis. Sort of a U shape and a straight pin
shackles and fixed pins, stick greasable ones in it so you can keep them well lubed up, it keeps them moving a lot freer (and quieter :D ) and holds back the rust on the pins reducing wear in the bushes and lengthing the life of the bushes, and being a cruiser with the front shackles at the wrong end of the springs anti inversion shackles save you flicking the shackles inside out and bending the leaf springs :?
Pj_Marsh
Post by Pj_Marsh »
I'll have a nosey at those anti-inversion ones too then
