1UZ Rear sump or aftermarket
Posted: Tue Feb 21, 2012 6:24 am
by QUADRACER
after a contact or rear sump for a 1uz, are there any tested modded sumps in NZ, or someone who has build one.
any info would be appricated.
Re: 1UZ Rear sump or aftermarket
Posted: Fri Mar 09, 2012 3:00 pm
by Madaz
Yeah, i run a modified rear sump on mine, been sweet as.
Have heard a rumour that you can go to toyota and buy a rear sump assembly of a 2uz cruza v8, for surprisingly less than you would expect.
I have seen a couple fitted, and they look pretty good.
Posted: Fri Mar 09, 2012 3:09 pm
by LOLYF
I have a 2uz sump on my 1uz, getting it direct from japan from a mate it still cost $900. From toyota NZ was something like $2000 :roll:
Which actually sounds cheap compared to the $3000 I was quoted for an idle speed controller :roll: :roll:
Posted: Fri Mar 09, 2012 4:03 pm
by lexlux
yep same , i run a 2uz sump on my 1uz hilux , it moves the sump back & to the left away from the hi pinion diff head .
Posted: Fri Mar 09, 2012 6:37 pm
by Madaz
LOLYF wrote:I have a 2uz sump on my 1uz, getting it direct from japan from a mate it still cost $900. From toyota NZ was something like $2000 :roll:
Yep, I hear ya
$1500 ea for a 1uz coil of toyota NZ :lol:
Posted: Fri Mar 09, 2012 7:27 pm
by LOLYF
cheaper to just buy another motor eh :lol:
Posted: Sat Mar 10, 2012 9:11 am
by haydgq
Yea they are a shocking price, they have a retail of around $6000, if you have a trade account they are $2500ish, Toyota NZ cost price is around the same price you can import your own from Japan but you have to know someone high up at Toyota NZ in Palmy to even go there 8) 8)
Another option is to buy a sump flange from Trade Me and make your own to suit or get your own flange laser cut and do the same.
I plan on getting a 2UZ rear sump from TNZ soonish to aid with my lack of up travel but for the last 4 years ive been using a standard front sump and i put a extra 500mls in just to be safe, but with the factory baffle system ive never had any oil starvation issues on angles etc
Posted: Thu May 24, 2012 5:33 pm
by QUADRACER
ok after testing new truck, still, a bit concerned about oil pressure, it is a mid sump.
any ideas or mods or just buy a rear sump for toyota
will a lexus lS 450 sump fit is this the same as a 2uz cruiser
Posted: Thu May 24, 2012 5:54 pm
by nztimr33
I was quoted $10,000 for a new starter motor for my 1uz from Rutherford and bond toyota.... :lol:
Posted: Thu May 24, 2012 6:24 pm
by Jerry
I've got a couple of starters and alternators and 5 coil packs sitting at home if you need anything .... make an offer or will swop for 1kzte ones one :wink:
Posted: Wed Jun 27, 2012 7:15 am
by QUADRACER
have brought a s/h rear sump, but need the dip stick and tube.
any one have a spare for sale ??
or should i just price from Toyota
Posted: Fri Aug 17, 2012 10:39 pm
by Big
This is what I did when I had the BJ70 , mine is a rear sumper and the bottom of the metal sump hit the diff head so I imprevised a little
And due to loosing the area in the cut I just added approx the same to the front of the metal bit, you can only just make it out.. have not had any problems at all with this setup.. and hopefully wont.. Running the same setup and it miss's the high opinion head almost the same spot..
Hope this gives ya some ideas.. :mrgreen:
