1uz blowing fuses??
1uz blowing fuses??
I've got a surf that has a 1uz put in it. I replace the altenator and ever since the charge light on the dash has never come on and the battery still hasn't Been charging. I had a quick play offroad on Sunday and it blew the ignition fuse and now blows them as soon as the key is turned. Any ideas as to what would cause this
Re: 1uz blowing fuses??
yep a pretty good guess you've wired it wrong
what did the replacement alt come off?
if its a 1uz alternator there are 2 different types i think (round and oval plug)
the old altenator was off a v6 windom, the new altenator was also off a v6 windom but had a slightly different number and had a round instead of oval plug. was told they would be fine to swap the ends over but im not sure
were you able to ID the pins or did you just guess the pinouts when you swapped the plugs over?
These might be helpfull...
92 LS400 charging
93 ES300 (windom) charging
92 LS400 charging
I used the plug and associated parts off the original altenator and swapped them onto the new one. It all looked the same so I thought it would be fine
so did you use a wiring schematic or just guess
do the 2 alts look anything like the pinouts in those schematics above, when you say they both looked the same were they the same colout wires?
they have slightly different internals .... which type do you need ... I have a spare one here i think
You may have blown a regulator or a main engine fuse as well
Never been able to understand those wiring diagram things, they just confuse me to much.
