Hi guys, going to be showing my truck a bit of love when I come back to NZ for a 'holiday', and thought while it is very easliy accessible I'd tinker with the motor slightly. Just after opinions on what I should do. Don't want to do a full rebuild, just a freshen up, new bearings?, seals etc. frost plugs? Oil has got a petrol smell to it as well which I'd like to sort out.
Thanks in advance
VP commodore motor freshen up advice?
Re: VP commodore motor freshen up advice?
I just brought a new stage 4 (drag) memcal for my 5l vp. Haven't used it yet but supposed to give around 20% power but you will probably use 20% more fuel (trailer rig so doesnt matter) it uses the Hsv tune. They are surprisingly cheap on trademe at the moment.
ford ranger wildtract and sj.
Check out the mace engineering website for all sorts of goodies for commy v6s.
- mud_slinger
bearings rings gaskets. sta parts in aux have good priced stuff brought my rebuild kit off them for ma diesel
needs more curry
0272593533
0272593533
007 wrote:I just brought a new stage 4 (drag) memcal for my 5l vp. Haven't used it yet but supposed to give around 20% power but you will probably use 20% more fuel (trailer rig so doesnt matter) it uses the Hsv tune. They are surprisingly cheap on trademe at the moment.
Wouldn't bother if I were you. Got a stage 3 for mine and all it did was take away some top end power. Was a waste of money for me, hopefully a better result for you.
tow99 wrote:Check out the mace engineering website for all sorts of goodies for commy v6s.
mud_slinger wrote:bearings rings gaskets. sta parts in aux have good priced stuff brought my rebuild kit off them for ma diesel
Thanks will have a look.
It cost just under 900 for rings/bearing/gasket set. For my VY, and thats at trade.
Cheers Daniel
Cheers Daniel
