96 HiLux DC 2.8D front axle seal/Birfield joint trouble
- mikeyt1689
- Bush Crasher
Re: 96 HiLux DC 2.8D front axle seal/Birfield joint trouble
checked your bearings?
If you've pulled it all the way down to the birfield, was there any play in the wheel bearings before you undid the retaining nut?
Check out your swivel bearings to by testing for any up and down play in the hub housing.
If there was no play anywhere, maybe you need to look at the brakes.
I've never had any issues with standard oil seals, I get mine at a seal place in Porirua here in Wellington.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
danielmoore.co.nz wrote:I am looking for some help to fix my misty.
it took me a lot of time to work out that said Misty and not Mitzy
I was returning home the other day when the front right wheel appeared to bind up and pulling the whole vehicle to the right (into on coming traffic) and making some horrible noises in the process
did you pull over and check it and it came right after you stopped or did you just continue driving home like that?
probably a bit late now but it would have been worthwhile (without burning yourself) checking to see if anything was hot ie: was the brake rotor cooking and glowing red hot or was there a lot of heat coming from the hub or swivel housing?
if everything in the hub looks ok now that you have stripped it could have been something simple like something flicked up off the road and jammed in the rotor
- tomsoffroad
- Flopsie
May be a sticky piston in your calipar? Spose that wouldn't make much noise tho
my guess is one of the caliper bolts has fallen out... had that happen once!
tomsoffroad wrote:May be a sticky piston in your calipar? Spose that wouldn't make much noise tho
Seized piston in the cruiser made horrible squeeling noises, and with the added stone trapped between the rotor and the guard it made real horrible noises....
Who knew Prados could fly?
