After mucking around with the standard window switches, and having been quoted too much for second hand replacements, I've done a pinout and rebuilt my drivers door console.
Jaycar has some pretty good replacements..... all up I've spent just under $30 and have a reliable setup. Simple panel with a door lock switch and switch for the 2 windows. Did away with the window lock.
http://www.jaycar.co.nz/productView.asp?ID=SK0980&keywords=rocker+switch&form=KEYWORD
Just gotta grab another for the passenger's side now.
Elec window switches - replacement
uptomynutsinruts
Re: Elec window switches - replacement
Sounds like a great cheaper replacement that should work out well eh
any chance of telling us how u did it and which wires go where from factory plug to new switches?? would be much appreciated lol wana do the same to mine.
Problem solved?
jono27 wrote:any chance of telling us how u did it and which wires go where from factory plug to new switches?? would be much appreciated lol wana do the same to mine.
I did not note down the exact colour to colour match....
I'm doing passenger side, coincidentally brought the gear today, so will make note and post it up when I get time.
So is this the fix if your windows go one way and not the other? I have a passenger window in my five door that will only go one way, but if you switch the feed to the motor it works the other way round proving that the motor is OK.
