Will a 70series Snorkel fit the Baby Cruiser?
juz
Post by juz »
Nobody seems to have a Snorkel listing for KZJ/LJ Landcruiser, but plenty for the normal Narrow 70series, anybody know if one will fit my LJ71?
much thanks justin.
Re: Will a 70series Snorkel fit the Baby Cruiser?
Yes depending on the model .... Mine is not the right one and sort of fits ... Google arb catalogue for the right one ... The body isthe same but front chassis and guards are smaller ... Taz can get hold of some cheaap ones at the moment
1hamish1
Post by 1hamish1 »
I bought a stainless one off a 70 for my lj71 and ended up cutting and re welding it. It was close but not quite there. The bonnet and guard angles are slightly different.
you want SS73HF or compatible
http://www.safarisnorkel.com/docs/snorkel/toyota.html
if its pre 90 you want the "bundera" one SS71HF
kbushnz
Post by kbushnz »
When I got mine some 10 years ago for my KZJ78 it came from Chch.
I think it was Hoskins ???
They supplied the snorkel and an additional adapter kit to fit it upto the air cleaner.
The adapter kit was designed by a 4 wheeler in Chch (Think it was Paul Delius)
Not sure if they still make / have them.
Fitted up sweet...
oldblue
Post by oldblue »
Safari Snorkel, Cut the outlet tube off the snorkel and move it backwards approx 20mm ,reweld back. This saves you cutting out the inner guard panel and the snorkel tube will line up with the air cleaner pipe work. check twice before cutting. When cutting the outer guard make sure the hole is repositioned to suit.
Return to “Tool Shed”
