Grand Vitara transfer
Posted: Fri Mar 02, 2012 6:24 pm
by unadunted
Gidday Guys. What could be the problem if a Grand Vitara transfer lever can't be shifted? Apparently hasn't been used in 4WD for ages. I know the SJ's problem where the shifter stuck due to worn shifter sheet. Would this the same thing?? Thanx in advance.
Re: Grand Vitara transfer
Posted: Fri Mar 02, 2012 10:31 pm
by churchill
Silly question but have you tried putting the gearbox in neutral before shifting the transfer lever? I know mine will only move into low in neutral.
Posted: Sat Mar 03, 2012 5:37 am
by unadunted
Ta Churchill. I haven't seen the car and not familiar with them. Was told the lever won't shift at all, not from 2wd to 4wd or into low. Rob
