Distributor Ignitor
Re: Distributor Ignitor
I'm assuming it's modern equlivent of a coil. I trust you've found Gee Motors in Napier; they should be able to sort you one.
1990 Niva 1600, Weber & 2" lift
Baxter's Niva Site: www.ladaniva.co.uk/baxter
If you do not have anything to occupy yourself - buy a Niva.
- Nivapulledout
sounds like someones Strange name for a coil pack.
As Baxter said Gee motors in Napier have all the parts you will need
aerodramus wrote:Just have to get it through a warrant now! Quite a bit of play on the steering but not something that can be adjusted out apparently....
The VIRM (the rules for WOFs) says that the amount of play a manufacturer specifies is fine. Have a look in the manual - the amount Lada specify is larger than most WOF guys expect these days (and I've had to take my manual in before to proof this).
Having said that, the steering box is adjustable and can be tweeked up if it is out.
