map sensor manifold fitting
For all Suzuki related topics
dean zuk
Post by dean zuk »
Whereabouts would i be able to source one of these? as mine was broken as we were removing the engine from the donor truck.
For a G16a tbi
Heres a pic of the part:
Also what the part called? :oops:
Dean
muddyhilux
Re: map sensor manifold fitting
Post by muddyhilux »
id be suggesting wrecker as it'll need to be a sensor matched to the vehicles computer.pretty sure repco and the likes don't to map sensor replacements.maybe wrong though
ONOescudo
Post by ONOescudo »
I too had the same sender broken doing my motor conversion. Mud Bits sent 2 as there seems to be different hose sizes, the one I need has a 4mm pipe and the one I wont be using has a 6mm pipe, which you are welcome to have.
It’s a Manifold Absolute Pressure (MAP) sensor so sates the Haynes Manual.
Located behind the TBI threaded into the manifold.
http://www.mudbits.co.nz
Cheers MIKE.
ONOescudo
Post by ONOescudo »
Hay hers a thought. Could you take a picture of the bracket that holds up the right side of the air inlet pipe that’s across the top of the motor. I haven’t got one. Might make it a bit easier to fab one up or get the correct unit as I have been sent the wrong bracket.
Cheers MIKE.
dean zuk
Post by dean zuk »
Cheers for that gave them an email.
And yes i can take a photo of that bit for you when i dig it out :)
Return to “Suzuki”
