Hi all,
I have an 85 bj73 swb cruiser with 3b diesel in her , will a turbo from 13bt or even 4200 t/diesel fit and if so how hard and where can I get one to help my guttless shermin tank
turbo bj73
- niblik
- Sausage Shack
welcome..
i have a similar plan for my 3b.. there are some expensive after market options...
as for the 13bt, from what i understand these motors are the same unit only one is turbo'd.. maybe just need to check the mount points on engine etc.. see if all appropriate bolts and/or holes are present for mounting the turbo onto your 3b as the 13bt may be a bit different....
will be interested in responses and sorry i cant help..
if you need any pics or info on the 13bt.. i have one outside.. i believe that a 13bt is a 3b turbo'd.. so basically its a manifold (for mounting turbo) a ct26 blower is standard on a 13bt. up the fuel i guess.
I not sure what other stuff. i run my one at 17psi on full boost.. intercooled. with no trouble..YET
Id recommend axeing your exhaust too.. probably run bit hotter. I have basically no mufflers on a 1.5m pipe
