WTD Prado Leading Radius Arms Now 80 series dimentions
kbushnz
Post by kbushnz »
As per title.. Need a pair of leading arms for the beam axle prado..
Bent mine at the 24h Superwinch Challenge and need to replace them (been bent a few too many times now. :lol: )
kbushnz
Re: WTD Prado Leading Radius Arms (pair)
Post by kbushnz »
Bump, still looking.. Could get away with one at a pinch....
juz
Post by juz »
kbushnz
Post by kbushnz »
juz wrote:http://www.trademe.co.nz/motors/car-parts-accessories/toyota/engines/auction-465424841.htm
Thanks missed that one...
kbushnz
Re: WTD Prado Leading Radius Arms Now 80 series dimentions
Post by kbushnz »
Ok all those 80 series owners..
Can you get out your tape measures for me and take some measurements for me.
Here's a photo of the ones I want....
Thanks in advance :D
oldblue
Post by oldblue »
Leading arms on the 1993 Prado's were weaker ( cross section )than the 1994 onwards arms.
jeremy
Post by jeremy »
80 series arms are different apparently...
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=22&t=27767 (photo with dimensions in that topic)
oldblue wrote:Leading arms on the 1993 Prado's were weaker ( cross section )than the 1994 onwards arms.
...and yes I can confirm the later arms are thicker. Not sure what year the rear arms we bought were off, but definitely thicker than our original 92 arms.
kbushnz
Post by kbushnz »
Thanks Guys
I knew I had seen that photo but couldn't find it again....
1hamish1
Post by 1hamish1 »
Cheap as chips through toyota. Just picked up one for 190 bucks including bushes.
kbushnz
Post by kbushnz »
Yeah that's what I thought ... Try $400 + each from my local toyota dealer. ex Japan.....
If your man can get more PM me .... :mrgreen:
1hamish1
Post by 1hamish1 »
Got mine from waikato toyota also ex japan. Ring clayton in the parts department and tell him Brynn recomended him to you. He will look after you.
kbushnz
Post by kbushnz »
I think the 80 series arms would work and also solve the castor when used with a lifted truck....
But would need one in my grubby hands to confirm...
However new ones ordered ex Japan... Thanks 1hamish1
axel
Post by axel »
Hey calvin, did you give up on this idea or you still waiting on dimensions? FYI the Prado arms (dimension B) are about 10mm longer.
kbushnz
Post by kbushnz »
Hi Yah
I ended up getting new prado ones....But still interested....
I have a gut feeling the 80 series ones could solve the problem of caster adjustment....
Would like a pair to compare....
why not try caster plates :?:
kbushnz
Post by kbushnz »
coxsy wrote:why not try caster plates :?:
Keep it looking factory.....I have already modded mine so it done...
But would be interested if it would work....
axel
Post by axel »
Not sure if this helps or not. The prado one is the longer, straighter one on the bottom.
http://s1124.photobucket.com/albums/l57 ... G_1569.jpg
kbushnz
Post by kbushnz »
Thanks for the photo....
Gee they are close.
But I think the rear steering rod wont clear. The prado has a big goose neck in it at the axle end....
Oh well just an idea...
axel
Post by axel »
Hey Kelvin, I went all out this weekend and actually rested that 80series radius arm on the end of my radius arm bolts to see what you mean about the goose neck bend. Well it would actually fit in place i think. On my truck there would be about 5-10mm clearance between the rear tie rod. However my tie rod does have a "slight" bend in it. Not sure what would happen when it flexs up. And for me i think the caster adjustment might be too much but will do a bit of a calc to confirm. Check out the photos i tool for ya
http://s1124.photobucket.com/albums/l57 ... ius%20arm/
kbushnz
Post by kbushnz »
Thats interesting...
Thanks for the photo's...
I think the clamp for the tie rod would need moving around but it could be a good fix for a 4 inch plus lift...
And no cutting or bending...
Pity I have already tweaked my axle housing to correct the caster using factory arms...
I am sure other will be interested with what you end up with...
Good work...
axel
Post by axel »
Yea it would basically be a straight swap. All you need to do is drill a new set of holes 10mm forward on the chassis mount bracket.
